The left Bing carb on my R90/6 drips gas...aboout a drop a minute. I have replaced the float bowl gasket twice now but that has not helped. Could this be related to bad floats? I assume if the floats are bad then gas would continue to flow as long as the pet cock was open and the bowl would overflow above the height the gasket, soaking the cork gasket and causing it to leak. When I remove the bowl, open the pet cock and lift the floats the flow stops, which leads me to think my floats don't float, if you know what I mean. Any ideas?
