burnszilla
I noticed tranny oil leaking from my K75C. It's sprayed all over the inside left of the bell housing near the swing arm. The rubber clutch rod boot is dry as a bone. The gear shift seal is dry. I can't tell where the oil is coming from. Unless its oil from the old boot leak. Perhaps I should just clean it up and see if it leaks again.
