Bought the Stebel Nautilus Compact Mini Air Horn, and the Denali (SoundBomb) harness/mounting kit (plus their mounting bracket, when I first bought my 2018 RT (Wethead) and was exploring options. That was the path others reported taking. However, I also recall for RT's with the alarm system (and soon to add, the Skene "Alert" system which utilizes the horn to trigger their lights) were unable to use it after adding the air horn, due to loss of the OEM horn.
I'm finally just getting around to installing the horn now.
I've looked around, and haven't see anything specific on this issue, but has anyone tried splicing the blue and white OEM lead that connects the horn, so that it controls both the air horn and the OEM horn (which would need to be relocated elsewhere; the original location under the fork will be occupied by the larger air horn)?
I doubt that there will be CANBUS issues, as the power for the air horn is pulled directly from the battery (via relay). What say ye? Two horns connected to the single OEM horn lead?
Thanks.
Thanks.
