basketcase
What's that noise...?
I've noted the same thing since I began playing with it (IE 7) and made the original post.MEWAYBRIGHT said:I've been using it since it released and have so far not found any issues to speak of... I took a bit to get use to having several windows in the same window but after you get use to it it is not bad. You just have to remember to close out of a window instead of closing the screen... but it will ask you before you do it.
IE 7 is changing the squence of how I do some things, but that is a plus for me. To wit: I've saved the several sites I visit most frequently into a folder, and can open all of them simultaneously with just three clicks. Then, the tabs allow me to switch back and forth between the pages with single clicks.
Not bad.
I do close the tabs when I exit so I can keep it simple.
