Hi everyone,
I have a 2022 C400GT, and recently I've been experiencing unstable idle speed. This started happening after I cleaned the throttle body on my bike about two weeks ago.
After cleaning, the idle speed became erratic. I used the OBDSTAR MotoMaster scanner to reset the throttle adaptation value and also to reset the actuator initialization. After doing so, the idle speed returned to normal for a while.
However, in the past few days, the idle speed has suddenly increased, and it’s clearly not normal. I’m not sure if this issue is related to the reset functions I performed. I’ve learned that the BMW software on this device is the same platform as the OEM, and it also includes options to reset all adaptation values and reset the mixture adaptation values. I’m unsure whether I should execute all of these functions.
Has anyone encountered a similar issue? Any thoughts or suggestions would be appreciated.
