Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
Don't plug it!!! This comes up from time to time. It's a drain hole for the starter cavity under the top cover. In there are lines which connect to the crankcase breather that direct some of the oil-laden mist into the carbs. If those lines should break or crack, that oily mist will settle on top of the engine. Thus the hole is there to alert you to the problem.
And if you ride fast enough, the water can't get in!
