D
dlearl476
cjack said:Ahhh. A breath of straight dope. I was sure that this was just good old coax but all the urban theories......I can't tell if it's teflon, looks like polyethylene. Does it melt from heat of the soldering iron?
My original Roady had a large antenna, with a 4 conductor cable. With the advent of the RoadyII, they went to a two conductor coax.
According to the antenna repair how-to, yes, you need to be careful of melting the center insulation.
I don't think the cable would do well with a F connector, the cable is ~ 3/16th " thick.
