C
crgrbrts
I'd been annoyed - ever so slightly - by a burned out backlight bulb on my K75S instrument cluster. Due to the promised inconvenience of replacing it, however, I'd simply tried to ignore it.
While looking for K75 series items on eBay the other day, however, I came across the offering of an LED instrument pod backlight upgrade kit. I bought one. It arrived Saturday and I spent about an hour or so installing it today.
Basically - its a matter of gettiing to the mounting bolts under the instrument pod (which may or may not require a fairing panel removal on one side, depending on your bike) unbolting and unplugging the pod, opening the back of the pod and replacing 5 light bulbs with LEDS (they're a direct replacement). It's a little bit of a tedious process, but not difficult at all. The instructions than come with the kit are very useful and price for the kit is not bad.
The result is evenly lit, bright (but not blinding) and very pleasant night lighting for the speedo, tach and clock display. I recommend this easy upgrade.
