Yesterday I installed an aftermarket digital coolant temperature display with an inline temperature sending sensor. The kit came with most everything needed except for some cable ties and any terminals to connect the power wires. There were a couple of Scotch clips included but I prefer not to use them. Overall a pretty easy install. I temporarily connected the unit to the battery and ran the engine to test it and it's working as it should.
My problem is I'm having a difficult time deciding where to connect the power wires. If connected directly to the battery the display would be on continuously, there is no on/off switch. The wire cable is not long enough to route all the way back to the fuse block under the front of the seat. I would prefer not to splice in some extra length but I may have to.
Is anyone aware of an ignition switched power source that I could tap into for power to the temperature display? Ideally up in front. This is a 2014 G650GS Sertao.
