Trying to decide if I'm going to actually do the deed to my 96 R1100RT and remove the entire charcoal canister system. In trying to understand better the routing of the fumes from the tank to the injectors I have this nagging question.
Is the electrically powered device in the center of my photo what causes or powers the vacuum in the system?
My examination of the routing of tubes in the system tells me it is.
Capping the inlet tubes on the bottom of the injectors and capping the canister vent tube on the fuel tank nipple that supplies the fumes to the canister appears to be the only places you need to cap off to eliminate escaping fumes while bike is parked in the garage.
You can't cap the tank vent tube, which is the second vent line exiting the tank, directly back to the swingarm area where it is left dangling at your right heel.
Do I have this right?
