cabel lube
Just grease the ends of the cables. The inside is teflon and will react poorly to any lube.
Jon's right, just put a little lube on the drum thingys at the ends of the cable and you'll be set.
check your levers...
Check your lever/hinge assemblies for play, too. As they get worn & out of alignment, they can grab the drum end and eventually wear it off. Went through it a while ago, can't remember if a lever replacement fixed it or if I had to change out hinge parts. I broke 2 clutch cables within 3 months because I didn't know to watch for it.
