pdadenmark
Hi all,
I recently ran into an issue with the ABS unit on my BMW R1150RT. As seen in the attached photo, there is a multi-pin connector on the ABS module where the wiring harness plugs in. During some troubleshooting, I accidentally bent two of the pins, which caused an ABS fault that took quite a while to diagnose.
Luckily, I managed to carefully straighten them out, and everything is now working perfectly again.
However, my question is: What if one of those pins had snapped off completely?
Is it possible to replace or repair the connector on the ABS module itself, or would that require a full module replacement?
Any insight from someone who’s dealt with this kind of issue would be greatly appreciated.
Thanks!
Thanks!
