pierremc
I've got two other threads on the go but decided to share overall updates on progress.
To recap, I was pretty much given an RS1100s with a blown engine ($500CAD). I reluctantly took it knowing exactly what I was getting into.
Bike looked to be in decent condition over all.
Since walking it home I have:
To address I have:
- Pulled the bike apart completely and confirmed that rod bearing was toast, drained oil and saw a good amount of metal on oil plug.
- Assessed condition of transmission - some amount of metal on trans plug, input shaft 3/4 stripped, coating of old transmission oil film on insides of case (suggests to me that someone left oil in for too long at some point in its 35k miles life (oil was clean and new though)
- Disassembled transmission and carefully inspected all gears and shafts, sourced and replaced input shaft
- identified a broken mounting tab on rear frame where bottom rear of transmission fastens to frame
- Identified a bent front fairing bracket (this one pissed me off)
- Unnecessarily removed the block (head) dowels
To address I have:
- Sourced a used crank and rods ($85USD). Installed and buttoned engine back up.
- Sourced used transmission gears and input shaft from an R1150x - gears were different so ended up having to pull all the stuff off the good input shaft to replace mine. Input shaft is ready for re-install ($85USD)
- Fully wiped down transmission and thoroughly inspected all bits and case
- Got a welder to weld the tab back onto the rear frame/cage ($40)
- Got two new pistons and "jugs" to address very minor scoring on both ($40 each)
- re-installed the dowels using depths proposed by Anton L with some locktite for good measure...time will tell if I get away with this.
- Removed the block cylinder head dowels (see above). Really bad idea. Don't ever do this.
- Put engine back together the first time only to then later realize that even though I was super diligent about making sure timing chains were firmly seated on crank that left side was not...had to pull engine apart again. Super frustrating.
- In relation to the above, I then didn't follow rule #1 if successful DIY'ing which suggests that when you have f'd up, walk away and sleep on it. Instead, I tried I immediatelyl doubled down (as the sun was setting) and used Chris Harris's technique of tapping the cam-chain-tensioner pin out from back of engine to be able to access the left timing chain without having to split engine again. Well, I'm going to go way out on a limb to say, this is not possible, don't attempt it! My punch ended up marring the nice smooth channel that the pin sits in and I never got it all the way out so all I did was make my re-assembly job more complicated by having to smooth out the surfaces and pray that the silicon will still seal up the hole nicely. Don't try this!!!!
- Put oil pump back together (the second time) and mistakenly swapped the "outer gears" putting the 2nd one in first and the 1st one in second. They are identical except that one is about 1mm thicker (#2 is thicker). If one puts the thicker one on first (the #2), you are totally seizing up the pump when you fasten the oil pump cover back on. If you then try to rotate the engine when you have reinstalled the sprocket, you will encounter resistance until...you break the tab on the large timing chain sprocket which sits on top of the oil pump. Yep, snapped it. Amateur hour!!! Another sprocket on order. Dear Clymer: this one deserves some bold warnings in oil pump installation section!!!
