Hi, My '72 R75/5 starter will fire off while the bike is running.
That's the headline. I had this issue a few years ago and thought I solved this with replacing the relay (a few times), but it has come back...and now I'm stumped.
Here's what's up.
- The bike runs fantastic, I just got back from a 1900 mile ride around NE.
- This happens mostly during a long ride and bike is good and warm and the engine is at IDLE.
- It sounds like the starter engages for a nano second to 1 or 2 seconds.
- The bike runs perfectly when this is happening -if it's just a second, the slightly longer bursts seems to effect the bike a bit, but then it's gone
- It's so random and intermittent, I can't make it happen again to diagnose.
- I've traced the wires looking for pinches, I replaced the starter relay, I've cleaned the starter and did a visual inspection, I've cleaned the switch (it's original) and didn't see anything wrong with it. It starts the bike and the turn signals work fine and the lock out works (when pressed - the starter will not engage while the bike is running).
I'm at a loss here. Could the starter have an internal short? Did I miss a grounding wire somewhere? Could something else more serious be making this clanking/grinding sound? It sounds like it's coming from the front of the engine...
Any one experience this before?
thank you, Chuck
Here's what's up.
thank you, Chuck
