26667
the Wizard of Oz
Ok, I'll just admit ignorance here. Even my guru w lots of airhead experience was left scratching the olde noggin.
Stopped by Chi BMW and the airhead expert there said it sounded (the footpeg vibration at all speeds) like the high idle wasn't adjusted; in addition to balancing the carbs as per usual at idle they should also be balanced at about 3000 rpm.
If you adjust the cables to the proper fee-play, then fine tune w the stop screw, then readjust at 3k, don't you just screw up your previous balance???
My guru's gonna ask his guru, but any how-to advice appreciated.
