Prof. Robert
Well, that funny thing wasn't so funny. On the way to work Monday morning, I almost lost a valve cover bolt (the little rubber seal is/was missing). I'm not sure exactly when the bolt loosened up, but I lost about a half quart of oil--mostly down the left side of my bike and my left boot. When I tried to tighten the bolt, it did catch (sort of), but it spun rather freely; however, that effort and a half quart of oil got me home without any further problems.
Today, I finally had time to pull the valve cover off. And surprise, surprise, the threads in the boss (?) are stripped. Whoever did this knew he did it because he also used gasket sealer on the bottom of the valve cover gasket. Now I ask you, is that anyway to treat a perfectly (well almost) good motorcycle?
Anyway, my real questions are what is the best/easiest way to fix this problem--heli-coil, timesert, or do I have other options? Also, (if heli-coil/timesert is the answer) how do I determine what size heli-coil or timesert to purchase? And, can I drill the stripped threads out with a hand drill, or should I pull the head and use my drill press?
As you've probably guessed, I've never attempted a job like this before, but I'd like to give it my "best shot." So, if anyone has been down this road before, I'd sure appreciate the benefit of your knowledge and experience.
Robert
Robert
