Anyone have thoughts or suggestions on what would cause the idle rpm to drop on an 85 K100RT?
My typical ride is a commute of 20-ish miles to work. It includes regular stop-n-go traffic such that the engine gets a chance to drop to an idle on most trips. The idle has historically been between 900 and 1000 rpm and has not required any adjustments. The last adjustment was done in the fall of 2009 when I adjusted the idle, choke and TPS. I've added about 20k miles to the odometer since then without any changes (Current mileage 95,727 miles).
I noticed last week that the idle rpm has dropped to the point that the engine will stop if I don't keep the throttle partially open. The first notch of the "choke" (fast idle) is almost enough to keep the engine running. The second notch advances the RPM to about 1500. I have not noticed any changes in performance otherwise.
The simple solution would be to readjust the idle, but I'd like to know what caused the change to ensure that I'm not masking another problem.
To catch up on some routine maintenance while looking at the idle issue:
1) Checked valves (all in spec)
2) Changed fuel filter
3) Cleaned air filter
4) Checked the spark plugs (light coat of soot, nothing extreme, attributed to "smokey" startups while researching idle issue)
5) Checked for vacuum leaks (no visible cracks or changes in RPM when moving hoses, crankcase breather was replaced last year)
6) No obvious signs that the idle adjustment had worked loose or changed recently
7) Changed fork oil (unrelated)
8) Replaced fairing bracket (unrelated)
I estimate that it would take apx 1mm of adjustment on the idle screw to compensate for the decrease in idle speed with adjustments to the choke and TPS as needed.
Unfortunately the odometer decided to quit last week also, so I'll be investigating that issue this week also. It likely needs new gears but I haven't opened it up to confirm that yet.
In the mean time, are there any thoughts or suggestions on the what would make the idle RPM drop?
Thanks,
Monte
Thanks,
Monte
