How do you install (wiggle into place) the large front cast ignition cover while ensuring that the rubber points wire gromet is seated correctly. I can't see into the points area and it has no correct seating (tactile) feel. The last 2 times I took the cover off, the gromet had been pushed in toward what is supposed to be the sealed points area. That would leave the points open to water and dirt. I wish there were 2 separate covers, one for the points and then the large outer cover.
Any tricks to ensure and confirm the gromet stays in place and the points are sealed up. Thanks.
