37mm Aftermarket Fuel Pumps for '95 K75
72r60/7
13278
I am investigating purchasing a spare aftermarket 37mm fuel pump for a '95 K75. Just a few questions before I begin a search of the Auto Parts Suppliers, local and national for "on the road".
1. Does the 37mm pump body need to be shimmed in a 43mm vibration damper or do they require a whole new damper ring ?
2. Does a stock bag type filter on the bottom of a 43mm pump fit most aftermarket type 37mm pumps ?
3. Anyone have a reliable brand name or part # for the aftermarket pumps ?
Thanks,
Charlie
There are some vendors that offer K75 replacement fuel pumps at a substantial savings over OEM -
https://www.beemerboneyard.com/16141341231nk.html [Beemer Boneyard may have a less expensive fuel pump with sleeve; I believe that there is a discount for BMWMOA members]
https://www.euromotoelectrics.com/EnDuraLast-BMW-K-52mm-Fuel-Pump-16-12-1-461-576-p/fp-576edl.htm [This is just the pump; vibration damper, filter, and hoses also needed]
https://www.amazon.com/gp/product/B00T5MKO6Y?psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s00
More discussion of replacement fuel pumps on other forum -
http://www.motobrick.com/index.php?topic=7066.0
YouTube video illustrating replacement of fuel pump with non-OEM (i.e., less expensive!) parts -
<iframe width="560" height="315" src="https://www.youtube.com/embed/2J1hALYaPGk" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
Wonder where the guy in the YouTube video got that submersible sleeve ?
Charlie
Euromotoelectrics.
I'm more curious where he found a store that stocked a pump for a Fiero! IIRC a pump for a 4cyl Mustang is a more common replacement.
I wouldn't use that pump as it uses a special electrical connector and the pump looks noticeably shorter. I've used the pumps from Euromotoelectrics for over 50,000 miles and 20,000 miles on two bikes and they're still ticking.
:dance:dance:dance
I've used a few pumps also from Euro Motoelectics. Good business to support.
I primarily was interested in alternative fixes for "on the road" when you forgot to bring along that spare pump. Now, what would be a good material to shim a 37 mm pump body in a 43 mm isolation dampening ring. Hey !, pieces of rubber hose. It's a little Walter Mitty stuff but nothing wrong with being prepared.
Actually, I had a couple of false (non) starts lately, like the pump was failing. I have a spare. I hope it's not the wiring, cause a spare pump will not do any good.
Charlie
