Thank you for reading my request!
Was riding N.C. area and descending from the Blue Ridge Parkway on rt 215 (a wonderful road) on my 2004 R1150RT (ABS 2 spark plugs). Downshifting before a left turn and my back wheel caught some gravel and went down. Bike side slid quite a distance. Engine still runs. Here is (what I think) is the extent of the damage:
Fairing etc. parts
- Headlight fairing damaged (ground away) around the left mirror mount
- Left side fairing ground down where it meets the mirror mount
- Glove box lid cracked (but still usable)
- Left mirror housing and glass cracked
- Mirror snap on pegs ground down
- Left mirror mounting bracket bent
- Center instrument console ground some on lift side at contact of left mirror/headlight fairing (useable)
- Handlebar stem mirror ground some (glass still intact!)
- Left luggage case ground (considerable)
Engine & other parts
- Left handlebar broken off where attached to handlebar extension (all controls seem to work!)
- Left valve cover ground down (also foot peg bracket bolt bent and allows oil to lead from that bolt hole)
AT a minimum to get it riding I need:
- Left handlebar
- Headlight fairing
- Mirror snap-on pegs
- Left valve cover
Questions.... I am having trouble getting the headlight fairing off of the bike.
- Do I need to remove the side panels to get the headlight fairing off?
- Do I need to unbolt some part of the mirror mounting brackets (both sides) to get the headlight fairing off?
- What what I have listed, could there be other hidden damage that I might be unaware of?
Thanks so much for any advice you can provide!
Allen
Fairing etc. parts
- Left handlebar
- Headlight fairing
- Left valve cover
Allen
