Lots to digest, guys and now I wish I had waited a bit to order the new battery (it has been shipped already and scheduled to arrive next Monday).
I have other LiFePo4 batteries and 2amp / 6amp LiFePo4-specific chargers here for my amateur radio use (as well as power outage backup with a 2000-watt inverter and two 100ah jobs). I will look into replacing the regulator as suggested, too.
Cold weather not a problem here on the South Texas coast; we have about 9 months of summer in between a month or two of usually mild winters and windy spring.
While that's great that I don't necessarily have to remove the tank, I've been thinking that if I do remove it I could strip the paint and polish It out to bare aluminum while it is off as I did years ago with my dear departed Berlina:
Since I have other bikes to ride in the meantime it's not a big deal for the extra downtime, especially if I'm going to need to install a new regulator, check the radiator and so on. I am also planning to remove the lower fairing and cut it down like I did with Berlina (or leave it off completely since it's usually hot here most of the year).
Tomorrow I'll contact Euromotoelectrics about an upgraded MOSFET type regulator; even though the Bosch battery I bought already has an internal BMS
(This is the battery coming; I ordered the last one in stock)
I just checked the coolant level and it is up beyond the MAX level mark close to the very top.
Thanks everyone for the suggestions and criticisms; all are appreciated. Getting old sucks!
--Z
--Z
