sundance71
Hello Folks,
I just rebuilt my brake system (new lines, pistons, seals, rotors, pads). There is still some old fluid in the master cylinders and ABS pump but the calipers are empty. I read the PDF by Dana Hager and Charles Gilman.
With the new pads and rotors, the pistons are pretty much all the way in the calipers. Is this close enough or do I still need to pull them off and use the wood blocks?
Chris
Chris
