when you say remove the windshield assembly, I assume that you're referring to the metal frame that contains the windshield motor, gear assembly, arms, etc. Is that correct? I looked at this assembly closely and I saw that there appear to be 5 screws in total, 1 on each of the 4 corners and 1 more screw mounted upside down near the motor itself. At this stage, I think it would be a shame to get this far in the game and not replace those instrument bulbs.
Yes, that's what I meant. I figured that if you were working on the windshield you might have already removed it. If you haven't yet there's no need.. just pull the instrument panel out from the front (that is, toward the rear of the bike).
By the way, does the RID (Rider Information Display) have a bulb that can be replaced or is it not user serviceable?
I didn't pay much attention to that one, so I don't know.
Also what about the speedo and tachometer lights? Do I have to open up the back of the gauges to access the light bulbs or are they accessible like the instrument cluster bulbs? eg...neutral light, high beam indicator, low oil light, etc.
You need to pull the gauges out of the instrument panel back case to access their light bulbs. It's not difficult but you need to exercise care. After removing the nuts from the studs that protrude through the back case I found that the gauges were still stuck in the case. I tapped lightly on the studs with a small hammer to get the gauges loose enough to pull out. You may not need the hammer; just push on the studs an see what happens. Remember, these are relatively delicate mechanical (speedo) and electromechanical (tach) instruments.
