slatefish
well here we go , after the screwed tire after about a hundred miles the abs lights are a flashing, alternately off course, several questions , will this pass inspection in mass? anyone in central mass have a diagnostic 911 that will work on this bike? there is no servo noise at front or rear brakes function seems normal . tried cleaning pick ups, and clearances are good on front but rear seems a little tight would this be enough to trigger fault?here you go lee !! thanks in advance! p.s. tried the on off several times , would disconnecting the battery help ? put the battery on charger and it immediatly showed fully charged.
