radrider
RadRider
I replaced my tires on the R1200R LC with PR4s. All went well but upon balancing the wheels/tires alot of weight is required to balance them. The front is balanced with 103gms and the rear with 78gms using a static balancer. The weight is needed on the opposite side of the valve and the TPM sensor. The BMW specs are within 5gms for the front and within 45gms for the rear. The maximum weight is 80gms. Should I remount the tires and rotate them and see if it changes or should I just place 80gms and call it a day?
