motocamper
Greetings All
On I 80 in Iowa the dash and GPS went dark and the speedo and tach went to zero while doing about 80 mph cruise control quit. The RT continued to run at 80 mph, just as if nothing had happened. this lasted less than a minute then everything returned to normal but the on board computer reset all to zero. The GPS changed routing. We pulled off the next exit had lunch called dealer, advised to continue riding if everything is still working correctly if not call bmw roadside assistance. We started the rt up and low beam headlight bulb was blown, but the bike worked fine. Road her back to PA with no trouble. Any ideas?
Thanks Tony
Thanks Tony
