What kind of prep did you do on the painted engine, especially since you didn't take it all the way apart.
Also, roughly how much does it cost to powder coat the frame?
The engine is still in process... for all the other parts that I did, I took them down to bare metal, mostly using Nyalox brushes, which are nylon brushes infused with an abrasive. I then cleaned with isopropanol, followed by a second clean with duplicolor prep spray, using blue paper towel, till no dirt was present anymore. Many hours spent on prep!!!! Then three coats of each "color": primer, black and then clear, per the instructions on the can, which call for two light coats, followed by a heavy coat, all with a 10 minute dry between coats. The engine I decided to try a bit differently as I was not too happy with the masking results I had on the cam covers. With those, I masked off the fins, and went through the primer and black, then de-masked and did the clear. I was not happy with the masking lines... I wanted to try something different on the engine - (paint, dry , sand paint off the fins and then clear coat afterwards). I asked Duplicolor, and they actually replied. They said it was fine to clear coat afterwards, but wait the full 7 days that is needed for the paint to cure. I actually sanded them down today and will do the final clear coats tomorrow!
I had the frame, swingarm, fork legs, fork clamps, center-stand and a hand full of smaller parts done for $400.
