I'm about to perform the 12,000 mile service. I wanted to also check the cam timing while I was checking the valve clearance. However, I can't find the alignment pin - TDC, # 83302327790. I can find all of the other tools. I know you can find TDC without the alignment tool, but can you adjust the cam timing without having the alignment pin to lock the flywheel in place so you can loosen the bolts on the cams? I have called about ten dealers/stores looking for the tool. I'm told that there are non in the US and Germany and they are on back order without an ETA. Has anyone else had an experience like this with finding the tool, any suggestions?
