TX Llano River flooding OCT16 2018
I figured you got enough freezing weather that the DOT would salt the bridges.
Maybe it does not happen enough to be a issue.
You're right about exposed steel being left bare on some structures now.
Back in the '70s and '80s there was a lot of use of "Corten" (sp?) steel. It was polished and then left to oxidize (rust) naturally. It would turn reddish orange but not get crusty. It was used as a "design feature" and was a bit of a fad. Minnesota used it for support columns and beams at some new Interstate rest areas.
https://en.wikipedia.org/wiki/Weathering_steel
The High Trestle bicycle bridge at the upper end of Saylorville Lake has uncoated guard rails, and whatever you call the upper decorative structure.
You guys are in love with this bridge. :ha
Because it goes somewhere:dance
I have that route as an automatic in my head and have headed to cross the river there a few times recently...and remember about the time a u-turn is required :banghead
The LCRA is going to raise the level on Lake LBJ for Spring Breakers ahead of the original plan of another month or so, assuming politics and tourism dollars played a part. Still submerged boats and docks and flood debris breaking the surface at lower level. Folks who scheduled repairs to property including docks and cleanup may not happen this year now. Crazy to let folks unaware of hazards out on lakes, but seems they will.
https://www.kxan.com/news/local/aus...mmodate-residents-local-businesses/1765667413
Have not seen if they located the remnants of the concrete decking of the knocked down bridge seen rolling in the flood current in earlier posts.
Guilty :)
I find this kind of stuff very interesting.
Wish they had a 2nd camera setup on the other side so I could see whats going on over there.
A drone video now and then would be nice.
Guilty :)
Going to check out the south side next week
Don't forget pictures :)
This last week several times I have seen cranes swinging in concrete with concrete buckets, but I can't see how they get the concrete out to the barges.
See if you can figure that out :)
Looks like they'll place more beams today.
I can see a beam sitting on a barge.
That's some serious equipment, there. Looks like they're working in the rain?
The NOAA site shows Fog/Mist now with the temp in the mid 40s.
Most of the moisture on the concrete is bleed water.
Have not taken that ride out there yet, amazed at pace regardless.
The LCRA raised the lake level ahead of schedule earlier this week as well. Lots of debris just didn't get cleared in time...I wouldn't do any backflips off a boat or anybodys dock on LBJ this summer:banghead
The weather has been heavy fog and some rain the last few days and temps from 75 to 40...a three day freeze is expected starting Sunday.
Laughed at the spray tank...I would have knocked it in the soup already:eek
They have at least three barge/tugs running from shoreline to work areas shuttling crew and materials...it looked well choreographed the day I was there
Seeing those rebar hoops for a barrier alongside the road surface shows a very wide bike/pedestrian path, which was promised:thumb
Visibility better there this morning...the truck on new deck would be hard to see here
That's some serious dollars!
Steve and Lee:
Did TDOT raise the elevation of the bridge over the waterway or are they inviting this one to go away too next time the river floods at record levels Just curious whether it is obvious that the approaches to the bridge were elevated a few feet?
