This is the no brake exercise. You can make slow u turns with just throttle, clutch and good body posture.
be aware that regular use of friction zone (the "other" FZ) on a single-plate dry clutch bike (all R and Klassic-K BMWs) will insure very short clutch life, which will insure either a costly or time-consuming replacement.
And that is why we teach new motor cops instructors to teach the no brake method for the cost and damage on clutch repair.
Is BikerFish and Motorman agreeing with each other or disagreeing with each other?
Hi John, long time no see.
Yes - basically both stating something similar, just from different perspectives.
When I trained as a Motor Officer, use of rear brake drag was essential to the proficiency of most exercises. The trainers however mentioned that to become an H-D Motor Officer Instructor, they needed to demonstrate the same maneuvers without use of braking, so as establish themselves at a level 'above' the students they taught.
I had two (one from the Michigan State Police, the other from Gulfport, MS) that admitted that after mastering the finesse of 'no brake dragging,' they still preferred occasional pressure on the rear brake pedal to smooth out their maneuvers.
I respect Motorman, and his skills are most likely well above most average Motor Officers, such as myself.
But having tried both approaches, I'll still be a 'trail-braker.' But like BikerFish says, do that sparingly with a BMW clutch, or get out your wallet.
Ride safe, ride often and ride ATGATT!
ok, taking the bait...
i feather y R1150GS' clutch a lot when traversing tricky sections off-pavement. At about 78k miles, the bike's rear main seal sort of needed attention and as a preventative I told the shop to replace my friction disk.
it was practically brand new.
so... either people are fanning their clutches while revving the bike too high (no need to rev) or something else is going on, but in my experience with both air and oilheads, the clutch is more than up to the task.
ymmv.
ian
Motorman - would you be willing to post the cone pattern for this course? I and a couple local motors would like to set up a practice course locally just for fun! Thanks
Careful here, quoting this comment: "But having tried both approaches, I'll still be a 'trail-braker.' But like BikerFish says, do that sparingly with a BMW clutch, or get out your wallet."
Not to steal the post or create another dialog, but "trail braking" in not dragging the rear brake through a turn. I had a MSF student last year, in a BRC ask me to watch for him "trail braking" during the class. I asked him if he knew what trail braking was, and he thought it was dragging the rear brake through turns. He was a fairly new rider on a CBR600.
Real trail braking is a technique of using both brakes, while leaning into a turn, to in effect cause the bike to "squat" down at both ends, thus shortening the wheelbase/decrease the effective fork rake, and make a bike with a conventional front fork turn in quicker. The idea is that blended braking into the turn apex, along with rolling up the throttle, makes the bike turn quicker with good stability and even chassis attitude front to rear. I mention the conventional fork because the Telelever fork on the Oilheads does not squat significantly like a conventional fork during braking, so the trail braking effect is less significant.
