Results 1 to 14 of 14
Thread: Side stand foot on a lowered GSA
    In January of this year I bought a 2017 GSA that has the lower suspension... I bought the side stand foot piece... And it seems to me that the bike sits rather up right... Does anyone else have this trouble heard. And as always thank you in advance
    Tom Casey
    2017 R1200gsa
    1975 R75/6
    My '16 RT has a sidestand foot and also sits pretty upright, to the point that if the ground slopes away even a little bit to the right, I can't park it. It is possible to get a bit more height by setting the suspension for "two up", but that is not a good answer. I will watch this thread with interest
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by stinkypete View Post
    The R1200RS sidestand is also too long. Did not realize the RT had the same problem.
    We set both of our RSs to Two Up so the bikes have a little lean when using the side stand.
    Lee
    2016 R1200RS
    MOA # 30878
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    I also have a 2017 GSA that is lowered and has an AltRider side stand foot enlarger. I use the middle pre-load setting (rider with luggage). I don’t have difficulty parking the bike on the side stand except on the occasion that I’m on a slope to the right. I often wonder what would happen if I’m pulled over to the side of crowned highway and the LEO tells me to dismount. Fortunately, no LEO has demanded that of me yet.
    Kevin Huddy
    Silver City, Montana
    MOA# 24,790 Ambassador
    Registered User gsinnc's Avatar
    Charlotte, NC
    Funny on my 2018 GS standard with standard height suspension I sometimes feel the side stand is too short and leans the bike over a bit more than I prefer. But i guess that is better than too upright. I use the dynamic or automatic suspension preload setting.
    Ed Apelian
    Motorcycling is my passion because golf is far too dangerous!
    2018 R1200GS - Light White !
    2016 R1200RT- Platinum Bronze
    I normally ride in the dynamic mode... I will try changing it the passenger mode to see if that helps... Thanks for the... If that doesn't work I've given some thought to having the sidestand cut and take a little bit out of..
    Tom Casey
    2017 R12GSA
    1975 R75/6
    Charlotte, NC
    Quote Originally Posted by blkb1rd View Post
    Tom Casey
    2017 R12GSA
    1975 R75/6
    Pretty sure the "pre-load" setting options on my 2018 GS are minimum, auto and maximum. Minimum is too low for me, maximum is too high but auto is just right
    Ed Apelian
    Mansfield,MA
    Shortening the side stand is pretty easy. I did both stands when I lowered the F800GS.
    Mod Squad
    2009 F800GS 1994 TW200
    Registered User wbrownell9's Avatar
    Jun 2013
    New Castle, DE
    I had a 2016 GSA low and the Altrider foot. I was fine with it but always paid attention to where I parked. Too much slope to the right - naptime. Too much slope to the left - can't get the pig off the stand and balanced. Standing it up then getting on - nope, not going to happen. I have to stand on a peg to swing my leg over, or hop to get one leg over the seat.
    One helmet except when traveling, when it was one helmet plus luggage. Yes, talking to the people with the pretty flashing lights on a crowned shoulder could be dicey. Even more so if there's a dropoff from the pavement to the shoulder
    Tom Casey
    2017 R12GSA
    1975 R75/6
    I'm not sure what you're trying to say. Dynamic mode is a throttle response setting (other choices are Normal and Rain). This is the MODE button on the right grip. Suspension damping modes are Hard, Normal, and Soft, and they change the damping, not the preload. Preload is what changes high the bike sits, on a 2017 your preload choices are one helmet, one plus luggage, or two helmets. These are changed with the "spring strut" button on the left handgrip.
    2020 R1250 GSA Low
    Charlotte, NC
    Quote Originally Posted by wbrownell9 View Post
    ??? Is that how the GSA options work? Those are the pre-load options on my 2016 RT but on my 2018 GS they are Min, Auto and Max.
    Ed Apelian
    Jun 2013
    New Castle, DE
    Quote Originally Posted by gsinnc View Post
    2017 GS is a wet head and has those settings. 2018 GS is a shiftcam with the settings you describe. The OP has a 2017.
    2020 R1250 GSA Low
    Old Rider - OK Mechanic 105258's Avatar
    Mar 2004
    Teulon Manitoba Canada
    Side Stand Too Long
    Cut about a 1/4 inch out of the side stand, either at the bottom or in the center. If you do the bottom take care that you get the foot plate back at the same angle of the foot plate will not sit level. If you cut in the center make sure you plug it before you weld it up. I have done several in the vintage of lowered GS/GSA and it make all the difference.
    David Nicholls
    Teulon Manitoba - Canada
    2015 R1200GSA-LC
    Mansfield,MA
    What I did to shorten the side and center stands-
    Remove stand from bike.
    Scribe a line down the center of the tube(s) to assist with later re-alignment.
    Pick a convenient spot to take a section out using a pipe cutter.
    Once the section is removed you will find the pipe cutter has “collapsed” the interior diameter a bit.
    Find a piece of rod or solid section of bolt and use it to rejoin the sections. There will be adjustability due to the pipe cutters action.
    Reference the scribed line for alignment.
    Weld the area where the two pieces of the stand(s) touch being careful to have the rod or bolt centered on the “new” joint.
    The first weld pass will easily pass through where the pipe cutter did its work fusing all three pieces together.
    Finish to suit- paint etc.
    Mod Squad
    Thank you for the excellent suggestions on how to lower the side stand... I'm going to look into that when I get back in about a week. Thank you all
    Tom Casey
    2017 R12 GS A
    1975 R75/6
  1. Side stand foot extension for 2019 1250 GSA Low?
    By pmiller@seyfarth.com in forum Oilheads
    Last Post: 11-06-2019, 08:58 AM
  2. R1200RT side stand foot
    By Ragman2 in forum Wetheads
    Last Post: 01-02-2019, 04:04 PM
  3. Web foot for side stand?
    By rbs3327 in forum Gear
    Last Post: 07-26-2009, 04:09 PM
  4. Side Stand Foot
    By leeines in forum Hexheads/Camheads
    Last Post: 01-21-2009, 01:14 PM
