Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
Thread: 1995 R1100RSL oil sight glass blowout on a trip
    Aug 2019
    New Jersey
    Hello -- I'm hoping Paul Glaves or others with infinitely more knowledge and experience on these matters sees this...
    I'm crossing the country on a 95 R1100RSL -- 2400 miles in, only 720 left to go for home.
    This morning I went to start the bike and heard the noise -- the oil sight glass blew out. I found it in the motel parking lot and it's intact. I made a bit of a mess on the motel's asphalt.
    I noticed a fresh oil drip was getting somewhat worse the past several days -- so this is entirely my fault for not investigating the sight glass before it launched itself.
    I cleaned it up with brake kleen added a very tiny amount of silicone adhesive to the edge (couldn't find Loctite Black Max) and was prepared to tap it in with a 30mm socket I'd just purchased for the task. As Paul has referenced in a previous post, it didn't need a socket to go back in -- just surprisingly light thumb pressure was enough. Had I known it would go in so easily, I might have used slightly more adhesive.
    So here is the question -- I have a new sight glass on the way to my house, 720 miles away... the old sight glass is back in and doesn't appear to be overtly leaking, but I haven't stressed it beyond starting it a few times and doing a very short road test.
    Any opinions on whether I should finish the ride home on the bike or if it should finish inside of a UHaul? The decision and repercussions are mine, of course -- but would appreciate any input. Surely someone has had to push an old sight glass back in while traveling? Decision time is first thing Tuesday morning.
    Thanks so much!
    Mitch
    Apr 2006
    Nibley, UT USA
    I had that happen on my Ď95 R1100RSL and did just as you did. I was 625 miles from home and rode the bike home with no problems. I did use some caution when starting the bike, especially cold, to make sure I didnít get any backfires as some of these have popped out with a backfire. Personally, if this is the first time itís popped out Iíd mount up and ride it home.
    Best,
    DeVern
    DGerber
    1983 R80ST ó 1984 R80 G/S-PD ó 2004 K1200GT w/Hannigan S/C ó 2010 K1300GT ó 2018 R1200GS
    Aug 2019
    New Jersey
    DeVern -- Thank you!
    That is really good to know. In reading about it, it seems this happens almost exclusively at start up -- I appreciate the caution on that.
    Again, thank you sincerely!
    Mitch
    Haven’t had this happen to my R1100 RS....yet. But, since your on the traveling, far from home, you might consider adding a small amount of silicone adhesive on th outer circumference. Just for a little piece of mind as you run down the road..
    2000 R1100 RS
    2009 Jaguar XK
    Aug 2019
    New Jersey
    Quote Originally Posted by walshj1024 View Post
    Havenít had this happen to my R1100 RS....yet. But, since your on the traveling, far from home, you might consider adding a small amount of silicone adhesive on th router circumference. Just for a little piece of mind as you run down the road..
    Thank you -- yes, I did add a very, very small amount of silicon adhesive before I popped it back in. Had I known how easy it was to press in, I probably would have used a little more of it.
    Registered User jrogers's Avatar
    Mar 2021
    Nor-Cal
    I'd go around the outside circumference again with more adhesive. Let it set up and never think about it again.
    02 R1150R ABS, 04 R1150R, 05 R1100S BCR, 16 S1000XR
    Aug 2019
    New Jersey
    Quote Originally Posted by jrogers View Post
    Thank you! Done (reasonably light film)
    Start your bike. Remove the oil fill plug. Listen carefully to that sound. Memorize that sound. Then while going home if you hear something like that sound stop and check immediately.
    Aug 2019
    New Jersey
    Well that sounds...like I should think UHaul.
    Definitely thank you for the input.
    Here is what I did.
    Sent from my SM-G975U using Tapatalk
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by GTRider View Post
    And once you get home, buy a new sight glass and install it.
    Excellent advice (as always) from Paul and DeVern.
    Aug 2019
    New Jersey
    Smitty -- that photo is impressive.
    BC1100S -- a new sight glass should be delivered to my house today.
    It is turning out less easy to find a UHaul in this part of Kentucky than expected, so I may be riding regardless. Obviously, I'd prefer to finish this ride on the bike, but don't want to hurt the bike, either.
    Thank you all, sincerely, for the input. I'm grateful.
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    Perhaps one of these in your saddle bag would be a good idea. Auto Zone expandable rubber plug. Not sure if it would work but may be adaptable.
    Quote Originally Posted by PAS View Post
    Yes - if a proper size it would work.
    Now to those early R1100RS bikes. The sight glass assembly is intended to be a dry, friction fit in the recess in the engine case. Some (most) early R1100RS bikes have a recess that is slightly too large. Instead of needing to drive the assembly into place it can be inserted with thumb pressure.
    For these bikes only I recommend an adhesive. Permatex Black Max (a black rubberized super glue) is my choice if it can be found. I want strong adhesive qualities, not just sealant qualities. What I have done is apply the adhesive to the back (inside) rubber ring around the metal so that when the assembly is inserted it adheres to the circular area at the back of the recess in the engine case.
    And my always final comment is that it is designed to be a clean and dry friction fit. When any oil manages to seep between the engine case and the rubber surround that oil will do what it is intended to do which is lubricate. So at the very first sign of any seepage at the sight glass it needs to be replaced as soon as possible.
    Left Coast Rider
    Nov 2011
    What a brilliant idea.
  1. sight glass '98 RT
    By bp@sr9 in forum Oilheads
    Last Post: 04-01-2018, 06:55 PM
  2. K75 oil sight glass
    By roncooper in forum Flying Brick K-bikes
    Last Post: 10-14-2012, 02:03 AM
  3. oil sight glass
    By 31310 in forum Hexheads/Camheads
    Last Post: 05-17-2010, 04:31 PM
  4. oil sight glass
    By rado360 in forum Oilheads
    Last Post: 09-29-2008, 11:17 PM
  5. More sight glass
    By TIGINBNA in forum Oilheads
    Last Post: 02-24-2007, 03:40 PM
