Results 1 to 9 of 9
Thread: Lamp error on dash
    Lamp error on dash
    My wife's 2014 F700GS has a lamp error on the dash. Checked all lights and the normal headlight bulb is out, all other bulbs are working. I go get another bulb and put it in and the message did not go away and the bulb still does not work.
    Ant thoughts?
    Mansfield,MA
    Which bulb is it? H-7?
    Mod Squad
    2009 F800GS 1994 TW200
    the back of the bulb says 12V55W7U Germany
    Mansfield,MA
    Pretty sure my F800GS uses the H-7......55 watt sounds right. Can you unplug the bulb and rotate the connector 180 degrees?
    Also, it would be good to check high beam.
    Not familiar with the F700, trying to assist through my experience with my F800GS. The bulbs don’t seem to last long in my bike.
    Mod Squad
    I guess if I look closely I can read the H before 7. I reversed the connector no go. It looks like I pull out the multimeter and check the bulbs.
    Old bulb bad new bulb check good with multimeter.
    Mansfield,MA
    The bike is running when you check?
    Mod Squad
    Okay one must start the bike to have the lamp error to go out and the light turn on. It has got to be a BMW thing.
    Mansfield,MA
    Quote Originally Posted by grabcon View Post
    It’s one of those goofy, especially if one would be used to “older” systems, that catches us all
    Glad it worked out for you.
    Mod Squad
    This is what great forums are all about
  1. I want to add a driving lamp...
    By BC1100S in forum Oilheads
    Last Post: 06-02-2015, 04:40 AM
  2. generator lamp out
    By Stappenbeck in forum Airheads
    Last Post: 07-01-2014, 04:20 AM
  3. Replies: 12
    Last Post: 04-18-2014, 08:36 PM
  4. RT Tail lamp
    By 71243 in forum Oilheads
    Last Post: 01-15-2011, 09:49 PM
  5. Head lamp !!!
    By soflopro in forum Airheads
    Last Post: 06-10-2008, 02:29 AM
