Results 1 to 5 of 5
Thread: H7 Headlight Connector - 2007 R1200 GSA
    TheRock58 TheRock58's Avatar
    Aug 2009
    Iowa City, IA
    Last week, the front headlamp burned out on my GSA. When I went to install a new bulb the plastic socket crumbled. I purchased a: https://www.repairconnector.com/prod...r-Pigtail.html :a new H7 2 pin headlight pigtail with the hopes of removing the terminal connectors and plugging the original connectors in the new plastic socket. How do I carefully release these terminals?
    If all else fails, I'll just solder the new pigtail in place. However, I'm sure I read where this has been done.
    Thanks in advance,
    TheRock58
    BMW MOA #152445
    2007 BMW R1200-GS Adventure (His)
    2008 American Saddlebred (Hers)
    Back in the saddle again mikegalbicka's Avatar
    Aug 2014
    Lakeland,FL
    I used Posi-Locks when I replaced mine with ceramic sockets.
    https://www.posi-products.com/
    So. California
    Not sure how my local dealer did this but when mine crumbled, they took the new connector, pulled out he wires and inserted the OEM connectors (that were exposed once the originals crumbled). No need to cut OEM harness, took about 25-30 minutes for two bulbs.
    Registered User patm's Avatar
    Mar 2016
    Montreal, QC
    Quote Originally Posted by TheRock58 View Post
    Thanks in advance,
    You can remove the terminals with a pin extractor. They are usually held in place by a small tab.
    I don't know exactly which extractor tool you would need but there's a large assortment of them on amazon.
    https://www.amazon.com/electrical-pi...n+removal+tool
    Pat
    Ride Safe!
    '16 RT
    Aug 2009
    Iowa City, IA
    I was able to locate the release on these terminals. There's a small bump on the bottom of the plastic socket, one for each terminal. I gently pried the terminal off the bump with a safety pin and it pushed right out. The small opening in the terminal captures the bump and secures it in the plastic socket. The terminals on the GSA snapped right into place on the new plastic socket!
    TheRock58
    BMW MOA #152445
  1. GS 911 connector conundrum 2015 R1200 RT
    By landev in forum Wetheads
    Last Post: 05-04-2020, 12:34 AM
  2. Replies: 0
    Last Post: 09-24-2017, 09:28 PM
  3. Replies: 11
    Last Post: 05-19-2017, 03:46 AM
  4. 6 Pin Headlight Connector 2015 R1200RT....Where?
    By daveyaffe in forum Wetheads
    Last Post: 05-17-2015, 06:41 PM
  5. 06 RT Headlight Connector
    By Jack D in forum Hexheads/Camheads
    Last Post: 05-31-2011, 01:51 AM
