Results 1 to 3 of 3
Thread: 2012 RT handle bar controls
    When I bought this bike 3 years ago the dealer replaced the controls on the handlebars under warrantee. The controls on the left side I would like to rotate just a bit. The horn is a little low. Can this be done without to much trouble? Thanks
    Registered User daveredman's Avatar
    Jan 2015
    west Michigan
    Quote Originally Posted by var1200rt View Post
    b u m p
    Var, Any resolution?
    02 R1150RT, 82 Suzuki GS1100GK, 86 VT500C Shadow
    Jul 2004
    Charlottesville, VA
    If it's the same as the controls I've dealt with recently, there is a bit of room to turn them. The wire from the heated grip is clipped to the inside of the switch housing but there's a bit of play in the wire. And while the grip is bolted to the handlebar, the switch housing is not. It's held by rubber pads so really just friction.
    I would look for the wire from the grip to the switch, then see if you can just rotate the switch body without pulling the grip wire tight.
    Anton Largiader 72724
    Tech articles - YouTube
  1. 74 R90/6 aftermarket controls
    By b5rider in forum Airheads
    Last Post: 07-05-2020, 10:41 AM
  2. 2012 K1600GTL Issue with clutch handle/lever grab point
    By dughuze in forum Straight 6 K1600 GT/GTL/B
    Last Post: 08-10-2017, 01:16 AM
  3. Disassemble Handle Bar Controls
    By b25bsaboy in forum Airheads
    Last Post: 02-18-2015, 06:43 PM
  4. 2005 1200GS with electrical problem with controls on handle bar
    By espressoforyou in forum Hexheads/Camheads
    Last Post: 08-25-2012, 08:57 PM
  5. '95 R1100GS Loose Handle Bar Controls
    By shropdog in forum Oilheads
    Last Post: 06-23-2011, 02:29 PM
