Results 1 to 15 of 15
Thread: Oil Filter removal tool
    Registered User DENKAR55's Avatar
    Sep 2010
    Scottsdale, Arizona
    I own a 2015 R1200GSA. I am looking for an affordable wrench to do my oil changes. Does anyone have any ideas where I can purchase one?
    Thank you ahead of time!
    Dennis
    Dennis and Karin Trovato
    2009 BMW R1200RT (In Europe) //// 2015 BMW R1200GS Adventure (In USA)
    Mansfield,MA
    Might want to mention your preferred oil filter?
    Mod Squad
    2009 F800GS 1994 TW200
    AZ
    MOA #107139
    RA #28511
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    This kind of cup wrench is better - it won't slip if a filter is stuck on tight, like the stamped steel cup wrenches:
    https://www.amazon.com/Hazet-2169-Oi...a-466246092922
    I've had mine so long it is marked "made in W. Germany."
    Harry
    My fleet: 2015 R1200GS, 2017 Toyota Prius Prime (plug-in hybrid)
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    I have used this type for years on anything from boats to trucks/cars and bikes.. Never encountered a filter that didn't come off...
    https://www.amazon.com/ATD-5208-Stra.../dp/B000OUZBTQ
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, 17 R1200RT
    Quote Originally Posted by RIDERR1150GSADV View Post
    I don't think that will fit into the location of the oil filter. It certainly won't with Oilhead or classic K bike filters.
    The strap tool that RIDERR1150GSADV mentions should work just fine for the OP bike.
    Here is another style that will work on our WetHead series that I use with great success.
    https://tinyurl.com/yssfnxuk
    I remove the plastic covers on the 3 arms to get metal to metal contact with the jaws.
    This version works whether your filter has different numbers of flats that are on the several versions of filters available from OEM/Mahle/whomever.
    This type is not usable for torquing the filter ON to the 11Nm spec. Most times following filter manufactures recommendations of turning 1/2 to 3/4 turn after filter gasket contact is slightly more than 11Nm anyway, so putting the filter on by hand works without any tools.
    Registered User REDC650GT's Avatar
    Feb 2013
    Grand Prairie, TX
    I looked at these yesterday and think Paul is correct.
    I purchased a new wet head recently and of course the original filter from the factory was different then the Mahle I have used on my previous bikes. So I thought I could use a strap filter wrench and the auto parts store had that type of wrench. I don’t think it would fit in there to be able to turn the filter. I did use the old style filter wrench with the smallest diameter I could find and stuffed some additional friction material in there to take up some of the slack remaining in the wrench and it came off fairly easily. Fortunately, I was able to use the cap wrench from Beemer boneyard to torque the new filter to spec.
    Good luck
    Chris
    If you can find someone with a 3D printer, they may be able to make one for you.
    Here's the link to the file in a format that can be used by a 3D printer..... https://www.thingiverse.com/thing:3612801
    Apr 2017
    S.Florida
    Correct as those bikes have the hidden-in-the-engine block filters.....
    MOA # 108516
    ohbeemer ramble's Avatar
    Jun 2004
    ohio
    My trusty 18 yr. old cap wrench has fit every filter I ever used, Mahle from BB or BMW from a dealer, but on the new 20 no go. WTF? So did get it off and back the the Mahle type. I don't understand why a factory new filter would differ.
    Minneapolis, MN
    Get one here for $6.99
    Order some filters too as long as you're placing an order for a wrench
    https://www.euromotoelectrics.com/BM...ench14f448.htm
    I don't see the deal they used to have, order 5 filters and get a wrench free.
    Steve
    '14 R1200 GS Adv bigjohnsd's Avatar
    Oct 2018
    Black Hills, SD
    The only dumb question is the unasked question!
    Team Pterodactyl - When we ride, we ride!
    K & n
    This is why I use K&N oil filters. They add the nut at the top so a standard socket (w or w/o extension) or a standard wrench works perfectly. Nice with a torque wrench if you're so inclined.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2018 BMW S1000XR / 2018 BMW R1200RT / 2015 Yamaha FZ-09
    Search all motorcycle forums at one time - www.MotorcycleForumSearch.com
    I use a cheapie metal strap type I bought at Wal-Mart 20 years ago, works fine.
  1. tool- Spark Plug Coil Removal Tool
    By galaxie in forum Hexheads/Camheads
    Last Post: 11-02-2016, 12:58 PM
  2. Oil Filter Tool
    By bogdan in forum Oilheads
    Last Post: 05-26-2016, 03:57 PM
  3. Pin removal tool for Amp connectors
    By rxcrider in forum Oilheads
    Last Post: 04-16-2016, 03:25 PM
  4. Oil Filter Tool
    By PaulWitt in forum Hexheads/Camheads
    Last Post: 09-05-2010, 09:37 PM
