I wanted to re-set my service light with my GS-911 WiFi tool so I searched the net but could not find specific info for my RT model. The plug is located on the throttle side of the RT, under the lower cowling Tupperware and in front of the battery. The plug is secured to the RT's chassis by male & female plastic rails. As you look at the plug head on, there is a latch located on the plug's upper left corner. Push the plastic latch toward the center of the RT and pull up on the plug, toward the seat to free the plug from its male rails. The plug has a cover which is released be pressing both sides of the cover to free it from the plug. As you'll see the female rails are part of the plug's cover. I hope this helps.
