Results 1 to 7 of 7
Thread: cruise control issues
    Apr 2008
    Waikoloa, Hawaii
    2009 Rt cruise control is intermittent, any info will be helpful, troubleshooting R&R pictures etc. thanks Woody
    RK Ryder
    London, Ontario
    A few years ago while on a trip, my friend who was leading, mentioned that he would be seeing his dealer on our return as his cruise control on his 2010 RT was frequently cutting out. I told him that there was an easy and immediate fix; keep his foot further away from the rear brake pedal. Problem solved.
    Your issue may be different but you might wish to consider this.
    Paul F. Ruffell
    Knights of the Roundel #333
    Quote Originally Posted by Paul_F View Post
    While following a friend, his brake light would come on and I'd see that foot resting on the lever. Told him via the helmet intercom. Hopefully I told him enough times his habit of where to rest the foot also changed. Myself, I've been pondering putting a small light near the dash that lights when the brakes are applied. Monitor my own foot and alert me to any issues.
    I will never ride enough
    West of Champaign Illinois
    Recall
    A number of years ago there was a recall on the handlebar switchgear. I was having trouble with the cruise acting up...work, not work, work, turn off...and so on... the dealer replaced it once and about a year later it happened again...then I got the recall notice and both sides were replaced and so far so good.
    2011 R12RT
    SPCLED
    2011 R1200RT
    Liaison 20774's Avatar
    This recall? This is for the Wedge-K bikes.
    https://forums.bmwmoa.org/showthread...K1300-GT-and-S
    Nope, the recall - replacement was performed in May 2015. I originally had the left one replaced under warranty in 2013.
    This was a multifunction switch recall and/or Technical Service Bulletin 61 005 14.
    SPCLED
    2011 R1200RT
    Hmmm...not sure I remember that recall. But you indicate it was a Service Bulletin issue. That might be different than a national recall by NHTSA.
  1. 2002 BMW K1200LT Cruise Control and Kill Switch Issues
    By mslacool in forum Flying Brick K-bikes
    Last Post: 07-09-2018, 02:59 AM
  2. Add cruise control?
    By dkthecpa in forum Hexheads/Camheads
    Last Post: 03-02-2018, 04:24 PM
  3. Replies: 8
    Last Post: 05-18-2016, 12:40 PM
  4. When did the RT get cruise control?
    By jcbappliance in forum Oilheads
    Last Post: 10-09-2010, 11:59 PM
  5. Vista Cruise Cruise Control for the Real F650
    By KPINVT in forum Thumpers - F & G bikes
    Last Post: 06-28-2010, 09:35 PM
