Results 1 to 3 of 3
Thread: Sag setting on lowered F700GS
    Anyone know the rear suspension sag setting on a factory-lowered 2015 F700GS? Total travel is 135mm but using the same 30% sag ratio used on the std suspension F700ís gives me a 40.5mm sag which is a setting I canít reach with adjuster. Itís a low mileage bike, I weigh 170# and the lowering was done by BMW so parts are correct and properly installed, but I can only adjust to min of 54mm. I canít find the recommended sag anywhere. Thanks
    Mansfield,MA
    Iím not sure anyone has been involved with that before.....
    Anyway, Welcome to the forum!
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    A 700 low does not have as much rear suspension travel as the regular shock model.
    Mine bottomed out occasionally but uncomfortably until i jacked the rear preload all the way up and adjusted the damper screw near the bottom of the shock. It was fine after that.
    FWIW, I weigh a little more than you, but not enough to make much difference.
    -Live as fully as you can as long as you can-
  1. Factory Lowered F700GS?
    By glenb in forum F-Twins
    Last Post: 08-07-2014, 10:24 PM
  2. Setting to retain all messages in thread setting
    By ron_ces in forum Forum Software Specific Help. NOT for bike related questions.
    Last Post: 04-19-2013, 10:41 AM
  3. lowered f700GS Payload...
    By samuelh in forum F-Twins
    Last Post: 11-19-2012, 06:29 PM
  4. Clock setting
    By TomBarnhart in forum Hexheads/Camheads
    Last Post: 11-26-2009, 05:13 AM
  5. torque setting
    By bensonhurst in forum Vintage
    Last Post: 01-31-2008, 12:57 PM
