Results 1 to 5 of 5
Thread: Odd '94 K75S brake switch issue
    Update ***
    I just installed a new micro processor switch, thanks EuroMotoelectric. Easy fix, although somewhat pricey part. All is well, brake pedal activates the brake light, as well as extinguishing the dash warning light.
    My 1994 K75 S has an odd issue with the rear brake light.
    When first starting, the red brake light alert illuminates. Riding off, it is supposed to go off, once the brake pedal or hand lever is pulled. But, the light does not go out, immediately, but usually after I travel a few miles it does go off.
    So, checking whether the brake tail light will illuminate, it only does when the handle bar lever is pulled, but does notilluminate by pressing the foot brake pedal.
    What I find puzzling is that the brake pedal does not activate the brake light, but apparently, it “ eventually” makes the red dash alert light go out. Does this sound like how these micro switches die?
    2000 R1100 RS
    2009 Jaguar XK
    Quote Originally Posted by walshj1024 View Post
    The mounting of those little switches is futzy (tech term). If loose what you describe can happen. Check the mounting of the switch. Also some electrical cleaner or even WD40 sprayed into the switch may cure it.
    Thanks, I will give it a try, although I have a new switch on its way.
    2000 R1100 RS
    2009 Jaguar XK
    To clarify, the light will go out only after BOTH the front brake lever AND the rear brake pedal have been pulled (not at the same time).
    The bulb check monitor checks 3 things: taillight bulb, brake light bulb as actuated by the front brake switch, brake light bulb as actuated by the rear brake switch. If you do not test both brakes, the light will remain on. If either bulb or either switch does not function, the light will remain on.
    The rear switch is a normally on switch, meaning that if nothing is pushing on the switch, the light should light. At rest, the brake pedal is pushing on the switch, thereby turning off the light. Sometimes the switch or the small lever that transfers the force from the brake lever to the button on the micro switch, can become bent or stuck, not releasing force on the microswitch button or the button itself can become sticky and not actuate the brake light. A new switch should fix it.
    The rear switch is a normally on switch, meaning that if nothing is pushing on the switch, the light should light. At rest, the brake pedal is pushing on the switch, thereby turning off the light. Sometimes the switch or the small lever that transfers the force from the brake lever to the button on the micro switch, can become bent or stuck, not releasing force on the microswitch button or thebutton itself can become sticky and not actuate the brake light. A new switch should fix it.
    2000 R1100 RS
    2009 Jaguar XK
  1. Ignition switch/lighting issue R100RT
    By mysteriousfish in forum Airheads
    Last Post: 12-04-2012, 03:28 PM
  2. K75s Headlight issue
    By donahue851 in forum Flying Brick K-bikes
    Last Post: 05-04-2011, 03:47 AM
  3. new K75S gear indicator switch issue
    By MCLEOD in forum Flying Brick K-bikes
    Last Post: 10-06-2008, 11:41 PM
  4. 93 K75s Brake issue
    By 118933 in forum Flying Brick K-bikes
    Last Post: 06-11-2007, 11:23 PM
  5. 1987 K75S Issue
    By arebin in forum Flying Brick K-bikes
    Last Post: 05-29-2007, 12:30 PM
