Results 1 to 3 of 3
Thread: 1985 K100RS rad/belly pan suitable screen replacement.
    Jan 2020
    Calgary, Alberta, Canada
    Have any of you guys replaced the screen on your belly pan or radiator shroud? If so, what did you use? Below is a pic of what I can get from Home Depot. A slightly different pattern but very similar in size. It comes in a large sheet but is only around $12. Cheap but a complete waste otherwise as I would have no other use for it. It does seem to bend easily so I would be able to curl it around the inside of the belly pan and then glue it.
    And the original rad screen as a comparison.
    Registered User jad01's Avatar
    Houston, TX or Portland, OR
    That does look pretty close, although the welds at the joints look a little more fragile.
    The OEM screen is still available new for the K75 models (and inexpensive)- not sure about the K100 models. However, if your current screen is still intact, you can pull it out, wire brush it, and repaint, which is what I did with my K75.
    Jim (MOA 83200)
    '78 R80/7 (Anastasia) and '84 R100RS (The Millennium Falcon), '86 K75C (Icy Hot)
    '90 and '93 Mazda Miatas (Jelly Bean and Red Hot), '97 Nissan XE PU (Mighty Mouse)
    '96 Giant Upland (big Kendas, baby!)
    JohnWC
    Mar 2010
    Akron, Ohio
    I find sandblasting works the best for jobs like that. It will look like new with some paint.
  1. 1985 K100RS possible rad fan replacement.
    By mcmlcccvrs in forum Flying Brick K-bikes
    Last Post: 03-17-2021, 10:24 PM
  2. 1985 K100RS Tires
    By stevenm in forum Flying Brick K-bikes
    Last Post: 11-07-2020, 12:17 AM
  3. 1985 K100RS non-start
    Last Post: 10-17-2020, 08:32 PM
  4. 1985 K100RS removal of air box lid.
    Last Post: 03-22-2020, 08:21 PM
  5. 1985 K100RS rad flush.
    Last Post: 03-04-2020, 04:57 AM
