Results 1 to 7 of 7
Thread: Adding some personal heat and convenience to the bike
    LegoHead CallMikeE's Avatar
    Feb 2021
    Denver, Colorado
    I did it, I drilled into the plastic today. I started riding in Colorado with a heated vest and the grips and seat are great but what about my vest?
    I decided based of what I have found online and in the forums to go with the HEX ezCAN, thank you guys!
    Controller - have a Gerbing permanent mount that came off my last bike but then I would have to drill even more holes in the bike and run a bunch of wires. This is my solution and it is not done I just started today and I will continue to update over the next day or so, we are getting 2 feet of snow so I will have some time in the garage this weekend.
    Solution - HEX ezCAN with their updated firmware you can setup one of the ports as heated gear tied to the grip settings, you define how hot the vest should be 20,40,60,80,100 based on the settings on your grips, big win! What about the wife she wants it on 100 all the time, I can use another port set to Aux lights #2 and adjust her vest in 10% increments, will be adding an LED up front to monitor the voltage and I can turn it on and adjust it all from the wonder wheel, another big win!
    Adding a Dashcam and my garage door controller to another port and using the final port for some police lights (red) I had on my other bike as additional brake lights.
    I have mounted the HEX ezCAN and the 2 panel mounts and garage door button, will get them connected after I have lunch with other fellow riders.
    With cables plugged in, the ring around the button is blue and will be on when it has power to the garage door controller.
    It must be snowing or the bike is getting maintenance because I'm sending this message MOA #223466
    Back Roads of Colorado on a 2016 - K1600GTL and it might be a gravel road.
    Feb 2021
    Denver, Colorado
    Update
    Good progress, both heated ports are setup and working with a status light for the back port. Garage door switch installed and wired up and installed the dashcam, overall everything fit and I still have a "little" room left under the seat.
    Installed with garage door button active:
    One of the wiring harness made for the heated gear:
    Picture of running the status light:
    Getting close to having everything tied in:
    Done for the day:
    Video showing the functionality of the second heated port,
    What is left? Still have to mount the front and rear camera for the B1M Dashcam, GPS antenna, and Mic, install my emergency lights as break lights with everything utilizing the HEX ezCAN device. I think it is a clean install I hope it helps others to see what can be done.
    Side note, it is officially a blizzard outside still have not canceled my Ironbutt for the first day of spring next Saturday :-)
    Mansfield,MA
    Nice work
    Mod Squad
    2009 F800GS 1994 TW200
    Feb 2021
    Denver, Colorado
    Updated video
    Okay I left all my tripods at work and with a snow day I thought I would give it a try.
    This is the current configuration.
    ebullient!
    Apr 2018
    Canterbury NH
    Very cool. I did something similar for heat, though I control mine via my Neutrino most of the time.
    I created attachment ports for two heat receptacles and added a garage door opener shown here by the two silver buttons on the battery cover.
    I also have an EZCan mounted for lighting.
    Feb 2021
    Denver, Colorado
    Nice work
    Bike looks great and you kept it clean under the seat, I mounted my camera under the headlight with a command strip. Rock solid on the video, still looking for a good place on the back, getting to much shake. Plan on taking the top case off so I might have to make a bracket to tie into the license plate.
    Debbie's Servant Lee's Avatar
    SW Iowa
    Quote Originally Posted by CallMikeE View Post
    If you want to get some brownie points from your wife buy her a heated jacket to replace her vest.
    Warm and Safe has the grey waterproof jacket on sale for $150.
    https://www.warmnsafe.com/collection...12594024579141
    Lee
    2016 R1200RS
    MOA # 30878
  1. Replies: 9
    Last Post: 02-11-2015, 04:35 AM
  2. Replies: 5
    Last Post: 03-05-2014, 05:15 PM
  3. K bike heat shield rattle: Easy Fix!
    By 90288 in forum Flying Brick K-bikes
    Last Post: 06-21-2004, 02:42 AM
