Results 1 to 3 of 3
Thread: low voltage to tail light
    I have a 2011 F650 gs, single cylinder with 5500 miles. I was riding it, hit a major bump and the entire rear fender broke off. The three wires to the tail light unplugged themselves and looked undamaged but, after replacing parts, I find I am only getting about 6 volts through them. Any ideas before I start pulling body panels etc.? TIA
    Mansfield,MA
    May be correct. If the running light looks good and it gets brighter when you hit the brake lever, I think you are good to go.
    Let us know.
    Mod Squad
    2009 F800GS 1994 TW200
    Aug 2018
    Fargo, ND
    BMW uses pulse wave modulation for tail lights on many of the recent models. In layman's terms, the ECM sends a pulse, on and off rapidly, to the tail light for running lights, and full battery voltage for brakes. It will show 5-6 volts under normal conditions and full 12 volts, (14 volts running) with the brakes applied.
    From the only real Fargo, ND!
  1. Any better tail light / brake light options for R1200RT?
    By westcoastkevin in forum Hexheads/Camheads
    Last Post: 09-14-2021, 11:52 AM
  2. Replies: 6
    Last Post: 08-02-2019, 11:05 PM
  3. '95 K75 ABS Secondary and Tail-Light Dash Idiot Light
    By stagewex in forum Flying Brick K-bikes
    Last Post: 03-26-2016, 04:10 AM
  4. Adding LED light to Brake/Tail light on 2011 R1200r
    By tonyd48 in forum Hexheads/Camheads
    Last Post: 10-31-2014, 01:59 AM
  5. tail light doesn't work/parking light does
    By ranbush in forum Oilheads
    Last Post: 07-15-2011, 02:25 AM
