Results 1 to 3 of 3
Thread: 1985 K100RS coolant temperature gauge.
Hybrid View
    Jan 2020
    Calgary, Alberta, Canada
    I picked up a spare temp gauge for my bike complete with the panel. When testing (plugged into harness, key on and grounding temp sender wire to frame) it takes about 2 seconds to fully deflect to the right. When performing the same test with the original the needle deflects instantly. Bad gauge or gauge going bad or nothing to concern myself with?
    Thanks,
    Tom
    Nibley, UT USA
    As in a delay of 2 seconds before it jumps to the right, or itís taking 2 seconds for the needle to make its way across? Some gauges are damped, to stabilize readings and avoid flutter. I donít know thatís the case with your temp gauge, but would consider it a possibility.
    Best,
    DeVern
    DGerber
    1983 R80ST ó 1984 R80 G/S-PD ó 2004 K1200GT w/Hannigan S/C ó 2010 K1300GT ó 2018 R1200GS
    Jan 2020
    Quote Originally Posted by GTRider View Post
    Best,
    DeVern
    DeVern,
    The latter. No delay. As soon as I ground it it moves. Your comment about flutter is interesting because my current gauge sort of jiggles around a little bit when it shows normal operating temperature, but when the needle is moving (heating up or cooling down) it's a steady motion.
  1. 1985 K100RS coolant boiling over?
    By mcmlcccvrs in forum Flying Brick K-bikes
    Last Post: 07-18-2020, 03:36 AM
  2. 1985 K100RS coolant capacity clarification.
    Last Post: 03-18-2020, 03:01 PM
  3. 1985 K100RS coolant filler cap
    By littledog in forum Flying Brick K-bikes
    Last Post: 05-21-2013, 11:47 PM
  4. Coolant Temp Gauge 1985 K100RS
    By walt3022 in forum Flying Brick K-bikes
    Last Post: 03-24-2013, 04:37 AM
  5. K100RS oil in coolant tank sight gauge.
    By OLDPILOT in forum Flying Brick K-bikes
    Last Post: 06-02-2011, 10:20 PM
