Results 1 to 6 of 6
Thread: MOTOMETER Clock question
    Is there a Motometer clock expert out here somewhere? I'd like to replace a white face Motometer clock in a handlebar pod from a /6 with a later model green faced version from an RS or RT. Does anyone know if the green faced unit will fit into a /6 handlebar pod? Is this a simple swap or will I need to start drilling and cutting to make it work?
    Registered User STEVENRANKIN's Avatar
    Spencerport, NY
    Same
    My understanding is the clocks for airheads are all the same size and are interchangeable. St.
    Clocks
    The early white face Motometer clocks were electric, using a rotating flywheel to advance the hands. (hard to find working ones and very expensive)
    The green face clocks are quartz movement, so swapping just the face might be an issue.
    It would be far cheaper to just swap the whole clock mechanism for the green face, quartz movement.
    Spencerport, NY
    Pod
    I am not familiar with the way the clocks were mounted in the auxiliary pods available at one time but on the RT, there is a bracket and two plastic nuts clamping to the plastic dash board holding things in place. Depending upon the flexibility of a person's hands, they can be a bear to remove from the RT/RS dash or no problem at all.
    I would imagine the "pod" uses some kind of nut system to make use of the two mounting bolts on the back of the clocks.
    The white face clock, was on my 74 R90S, The green face ones are on my R80RT and R100RS. All of them had the same mounting system. The white face ones are like hen's teeth, working green ones are also getting rare and pricy.
    Good luck with what ever you choose to do. St.
    Quote Originally Posted by STEVENRANKIN View Post
    On other models, you could order a clock or voltmeter and it looked something like this.
    Spencerport, NY
    pods
    Yes, I have seen the pod mounted Volt meter and clocks BMW made available for an option. From what I can see in the for sale sections and such, they are getting hard to find and expensive. BMW made them NLA a while ago. So far, no one like Siebenrock has brought them back to market. To be honest, I don't know if there would be a market for them?
    While I have seen them on bikes with not only the clock and voltmeter in them, I have seen oil pressure and oil temperature gauges mounted into them as well. Not just Motometer gauges but VDO and Sun. So there must be a simple method of mounting then into the pod, and as I have said, BMW wouldn't have spent money to design a unit for the RT and RS and S bikes and a unit for the pod bikes.
    So changing a white face clock for a green face one should be easy, but may not be cheap as they are NLA from BMW and are now in the free market for sale and price. Ebay lists them for sale in widely variable prices and of course, with Ebay, it is buyer beware. Oh that holds true for any seller of used parts.
    If you want to repair the white face clock, or change the face, that is more difficult as mentioned, there are two types of mechanism to deal with. There was a couple of years ago a link on the net about a fellow who had taken a green face clock apart and had repaired it. He gave very good instructions as well as pictures on the procedure. To be honest, with my fat fingers, I would not attempt it. St.
  1. MotoMeter Clocks
    By RPGR90s in forum Airheads
    Last Post: 02-28-2019, 08:58 PM
  2. MotoMeter Speed Correction
    By WooDmEn in forum Flying Brick K-bikes
    Last Post: 03-17-2018, 10:43 PM
  3. Question re: Clock going to 0 on Start
    By Blueman in forum Oilheads
    Last Post: 06-29-2008, 01:44 AM
  4. 1150GS clock/voltage question
    By FatChance in forum Oilheads
    Last Post: 06-25-2008, 06:18 PM
  5. R75/5 MotoMeter Repair/Rebuild
    By K12RS in forum Airheads
    Last Post: 01-22-2004, 01:14 AM
