r60celo5
Hello all.
As my rebuilt progresses, the list of parts to be replaced gets longer and longer.
After removing the timing chain cover i found that the timing chain was eating away into the crankshaft mount. There is slack on the chain and even with the tensioner on, i can push the chain outward to hit the spot it is chewing on. i hope this explains the tiny metal shaving i found on the oil. In a way i was preparing to replace the timing chain, the tensioner and the spring. The chain that was on the bike had a master link so i guess it had been replaced before.
i found that the camshaft sprocket is worn and the teeth are relatively sharp. There are also some nicks on the bearing outer race. Should i replace the sprocket? how bad doe it look? The camshaft sprocket looks OK.
and here is a picture of the tensioner. can i reuse it?
I have searched for any info or threads how to remove the sprocket from the crankshaft, and found plenty useful information. however everyone seem to use the special tool. Again i am trying not to buy expensive special tools that i will have no use for again. Rather spend that money into other parts or beer.
my questions is:
Can other tools be used to remove and install the sprocket and the bearing? Pictures would be helpful.
If the special tool is the only way to get this done. Can i rent it somewhere or from someone? I am located in Winchester NY, and happy to pay the shipping back and forth.
Thank you.
my questions is:
Thank you.
