Results 1 to 15 of 20
Thread: Any better tail light / brake light options for R1200RT?
    Sep 2020
    Dayton, OH
    Hello,
    2011 R1200RT
    I like night time riding and it is impressive the way the Goldwing and Harley riders have enough lighting at the rear. The BMW is not even close.
    Are there any options for improving this situation?
    Top case lamps?
    Extra lamp kits?
    I want to know what is out there before I take a DIY approach. It would be a bit more work because of the CANBUS.
    Thanks in advance,
    Kevin
    EDIT:
    I found some. Opinions welcome.
    https://www.skenelights.com/online-s...als-p199685741
    https://hyperlites.com/?product=3way...ngturn-signals
    https://www.clearwaterlights.com/pro...ant=6087900677
    2011 R1200RT
    TravelsWithBarley.com
    Jan 2009
    Craftsbury, Vermont
    I see youíve discovered both Skene and Clearwater. Iíve used Jerry Skeneís P3 lights and Clearwater Kristas for years; very noticeable! On my 2018 I added the Clearwater Billie brake light. The accelerometer feature is da bomb, but Iím not sure it works on Beemers before the WonderWheel came out. Or maybe it works but isnít programmable?
    Both are excellent with customer support. Glenn from Clearwater actually chased me down at the Sedalia rally to replace the faded bezels on my Krista lights free of charge! The fading hadnít bothered me, but he felt he couldnít have his product looking like that.
    Pete
    '18 R1200GSA for solo rides
    '12 R1200GSA with Hannigan sidecar for rides with Glenlivet
    http://travelswithbarley.com/
    Jun 2009
    Rochester, MN
    A big +1 for the Skene lights - in my opinion they work great, are very bright, and seem to garner attention with their subtle flicker.
    I'm also a big fan of the Admore light bar. I have the one with progressive turn signals, which I believe has been researched to be better at attracting attention as well as showing your intention.
    Aug 2018
    Fargo, ND
    You can add a reasonable amount of rear lights without adding a controller. I know because I pull a trailer with my 2018 RT with no added controller and no issues. The trailer has LED lights. If you just add a extra LED tail/brake light I would wire it up temporarily and try it before I spent money on a Can-troller of some sort. If you over load the circuit it will just shut down, no harm done, just remove the load and it should come back. You might need to cycle power.
    From the only real Fargo, ND!
    Back in the saddle again mikegalbicka's Avatar
    Aug 2014
    Lakeland,FL
    +1 for Skene
    Registered User gordsmarsredrt's Avatar
    Nov 2019
    Kelowna, British Columbia
    I'm happy with the Denali B6 auxillary tail/brake light.
    https://denalielectronics.com/products/dnl-b6-10000
    Gord - Current bike: 2018 R1200RT.
    Past BMWs: '77 R100S, '77 R100RS, ('75 2002)
    Registered User kevinsclo's Avatar
    Sep 2013
    Toronto, Canada
    Skene light
    Mar 2006
    Raleigh NC
    I added this to my 2013 R1200R and they make a huge difference in rear lighting visibility.
    https://www.weisertechnik.com/collec...r-ext-btc-bm01
    Check out the online videos. It's an easy installation.
    Doug
    Sent from a Galaxy, far, far away
    Registered User bicyclenut's Avatar
    Jul 2016
    Sugar Grove, IL
    Currently using Skene Aux Brake Lights, nice and bright. Attached to HEX EzCAN and flash upon braking and rapid deceleration. Previously used a Admore brake light bar and worked pretty well too.
    Photo of Skene lights.
    2010 BMW R1200RT
    2014 BMW C650GT (sold)
    MOA # 208387
    Sep 2009
    Cherry Hill, NJ
    People who see me riding my RT with Skene Photon Blasters (front) and P3 lights (rear), tell me that the lights on the bike are "annoying." I take that as a very positive comment on my increased visibility. I think that very subtle flicker which is built into the circuitry by Jerry Skene is a very useful characteristic.
    John Gamel - BMW MOA Consumer Liaison 2018-Present
    2015 Ebony Metallic R1200RT
    MOA #153274
    "We have met the enemy and he is us." Pogo-via Walt Kelly
    Registered User robbw's Avatar
    Mar 2018
    SW Ohio
    2013 R1200RT 90th Anniversary Edition
    Jan 2009
    Craftsbury, Vermont
    Quote Originally Posted by ExGMan View Post
    When I first saw Photon Blasters at a rally booth I thought Jerry Skene had gone off the marketing deep end. Then I saw them on an RT. Holy cow those things get your attention!
    Pete
    Sep 2020
    Dayton, OH
    Thank you all for the replies.
    I have a bit more reading to do.
    I want to strike the correct balance of brightness.
    I know that a tail light or brake light can be too bright and make it difficult of impossible to see a flashing turn signal.
    The same goes for running lights and headlights with the front turn signals.
    They need to be good in daylight, low light/driving rain, and night time conditions.
    The positive reviews of the Skene have my attention. I had not seen the Admore, so I will read up on that.
    Kevin
    2011 R1200RT
    The Blue Max 31310's Avatar
    Calgary Alberta
    Ran with Skene for years and liked them. Bought Admore three years ago and like them as the turn signals are amber and in my opinion, attract more attention from cagers. Both are excellent products, imho, can't go wrong with either.
    2007 R1200RT
    Skene P3 (Rear) Photon Blaster (Front)
    2018 RT
    I recently installed these for conspicuity reasons. Flicker is a real attention getter but it can be programmed to "off" if desired. Optional turn signal option on both front and back is a potential lifesaver, IMO. Mine also have an alert function on the front. 2 quick taps of the horn (or high beam switch if so wired) triggers a 4 second series of long and short flashes. The best part was the technical support I received from Bill at Skene. Immediate and accurate. All-in all - high praise for these lights. Did I mention flawless CAN bus connectivity and easy install?
  1. LED Tail/Brake Light Bulb
    By BC1100S in forum Wedge K-bikes
    Last Post: 08-04-2019, 02:59 PM
  2. Replies: 6
    Last Post: 08-02-2019, 11:05 PM
  3. Adding LED light to Brake/Tail light on 2011 R1200r
    By tonyd48 in forum Hexheads/Camheads
    Last Post: 10-31-2014, 01:59 AM
  4. LED tail/brake light R1100S
    By ANDYMCLAIN in forum Oilheads
    Last Post: 04-21-2010, 03:49 AM
  5. RTP Auxilliary LED Tail/Brake Light...
    By 1analguy in forum Hexheads/Camheads
    Last Post: 09-26-2008, 05:49 AM
