Results 1 to 7 of 7
Thread: Ground strap?
    May 2018
    Thousand Oaks, Ca.
    Ground strap?
    Help needed with what the cable thing under the seat is. One side is bolted, the other has a loop on it, but I canít sort out what it is.
    The manual doesnít seem to help, ground strap search came up with nothing.
    Thanks!
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    WAG - helmet lock?
    slave to gravity skibum69's Avatar
    Dec 2016
    New Melbourne, NL
    Might help to tell us what kind of bike and maybe a pic?
    http://beerthief.ca
    ITSteve: ride in peace my friend
    save $5 on a new SmugMug account, use this coupon 7frrnSRiTt9Fk
    Jun 2009
    Rochester, MN
    The other WAG: a lot of times on the GS's of that vintage, the small little rear access hatch would flex enough over rough roads, that it would pop off and be lost. Some owners would loop a safety strap of sorts around the lock barrel in an attempt to prevent this cover loss. Pictures are worth a lot in this scenario
    May 2018
    Thousand Oaks, Ca.
    Ah sorry, this is 1999 Funduro and yes, I think itís a helmet lock strap/cable now that I look at it. The idea being you loop it through the helmet and to that small metal loop under the seat, then lock the seat in, and youíve got a helmet lock? I guess it could work. Itís an odd design though, no?
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Perhaps not the oddest thing about a Funduro.
    Kevin Huddy
    Silver City, Montana
    MOA# 24,790 Ambassador
    Jun 2009
    Rochester, MN
    Quote Originally Posted by mykrs View Post
    Quite a few newer bikes come with a little loop somewhere under the seat, welded to the frame, so you can use your own cable (or maybe BMW sells one?). I'm betting they are choosing to go to this style of lock, instead of the standard metal U-loop, as many helmet manufacturers have done away with a d-ring chinstrap. Plus, some of us want to lock our jackets/pants to the bike too.
    Here's an example of what it looks like on an Hexhead RT - on the left hand side, looks like a "7"
  1. BMW tank bag strap repair
    By ldcleve in forum Gear
    Last Post: 06-10-2014, 06:15 PM
  2. where does this ground strap attach?
    By roostershooter in forum Oilheads
    Last Post: 09-26-2013, 12:46 PM
  3. Schuberth C3 Chin Strap Fix
    By bkallen in forum Gear
    Last Post: 06-20-2013, 12:53 PM
  4. Recovery (Tow) Strap for Motorcycles
    By drreese in forum Airheads
    Last Post: 01-06-2009, 07:34 PM
  5. Magnet or Strap Tank Bag
    By norseman9 in forum Gear
    Last Post: 05-17-2006, 04:47 PM
