Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Thread: 1994 K75S Dakar Yellow
  1. #16
    Sorry that you misconceived this thread. Look at post #1.
    Quote Originally Posted by Motodan View Post
    Lee, apparently this thread was his pre ad (spread the word) before the actual listing.
    2000 R1100 RS
    2009 Jaguar XK
  2. #17
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    It's all good. He never referred to the ad or the fact that it was for sale (neither of which is allowed).
    He just was inquiring about how many of this special edition were made. That information may help him with the sale of the bike. But that is fine.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
  3. #18
    Dec 2007
    Indiana
    Quote Originally Posted by walshj1024 View Post
    I was asking the other Lee, the one who asked you why you were selling it. I saw the pictures here. Why are you selling?
    '17 RT
    MOA #46783
  4. #19
    Not needed.
    2000 R1100 RS
    2009 Jaguar XK
  5. #20
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Is the front axle nut correct in this picture?
    I don't have any close up pictures of our old bikes to compare.
    Lee
    2016 R1200RS
    MOA # 30878
  6. #21
    Lee,
    That’s the one that it came to me with. It’s a Allen spindle screw, attached with 24 lbs. the clamp bolts are also in place, at 10 lbs.
    What looks out of place?
    2000 R1100 RS
    2009 Jaguar XK
  7. #22
    Lee,
    Thatís the one that it came to me with. Itís a Allen spindle screw, attached with 24 lbs. the clamp bolts are also in place, at 10 lbs.
    Normally the outside diameter of the head of the capscrew fits into the inside diameter of the recess in the washer/spacer. This leaves the end of the capscrew flush with the washer spacer. The capscrew in the picture is a replacement for the original.
  8. #23
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    The bolt in the photo appears to be a torx bolt. The original was a standard allen head bolt that fits inside the washer, like Paul said. Torx head bolts weren't used on Bmws for many years after the K75s were discontinued. Someone must have grabbed the wrong bolt when they misplaced the correct one. I would correct that.
    The correct bolt is still available:
    07 11 9 901 039 FILLISTER-HEAD SCREW - M10X20-8.8-ZNS $5.29
    Mine, Hers, Spare
  9. #24
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    If that bolt is NOT a torx bolt, it is probably one of the ABS caliper mounting bolts that someone put in the wrong place and put the axle bolt in the caliper.
    The ABS bikes had a special bolt that helped align the caliper to keep the caliper ABS sensor to ABS ring gap stable. It is the upper right hand front caliper mounting bolt and the bolt closest to the rear caliper ABS sensor.
    These two special bolts have a cast in washer on the head like your picture. They also have a larger than the thread unthreaded shank that fit the hole in the ear of the slider more tightly.
    Check the upper right hand caliper bolt to see if that is the standard allen bolt that belongs in the axle.
    Without the correct bolt in the ABS caliper, the sensor gap could change enough to trip an ABS fault and render the ABS inactive.
    Mine, Hers, Spare
  10. #25
    Thanks guys, appreciate your sharp eyes on this.
    The allen fastener on the front axle is going to be replaced with the correct BMW part. It has not changed the abs clearance, and the abs works fine. Not sure when that fastener was switched, but probably prior to my ownership.
    Thanks again.
    2000 R1100 RS
    2009 Jaguar XK
  11. #26
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Walsh,
    Does your upper right front caliper mounting bolt have a similar cast in washer on its head or is it a standard allen bolt with a separate washer?
    Mine, Hers, Spare
  12. #27
    Lee,
    The upper right side is a standard bolt, no taper, or washer.
    2000 R1100 RS
    2009 Jaguar XK
  13. #28
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    That is probably the bolt that should have been in the axle. The one in the axle should probably be the one that goes in the caliper. Both those bolts get removed when removing the front wheel (tire changes). If someone was not aware of the difference, it would be easy to get in the wrong places when reinstalling.
    Mine, Hers, Spare
  14. #29
    Lee,
    Thank you again for your follow up. I have switched those fasteners.
    2000 R1100 RS
    2009 Jaguar XK
  1. Pictures of R1200GS in Dakar Yellow
    By mtfrench in forum Hexheads/Camheads
    Last Post: 07-22-2009, 01:03 AM
  2. Dakar yellow K75S
    By QUICKDRAW in forum Flying Brick K-bikes
    Last Post: 03-06-2009, 10:28 PM
  3. Dakar Yellow paint code
    By unkabert in forum Flying Brick K-bikes
    Last Post: 06-07-2008, 12:28 AM
