2011 R1200RT ABS Issue
tsconver
Hooligan
Have a brake failure message on the screen. Looks like it is probably the abs module. What can I expect to pay for the module? Hard to find prices on the web. How much to install it if I decide not to do it myself.
I just repaired my ABS 2 on my 2010 RT. Not a difficult job to remove and reinstall. Maybe 3 hours total. The Tupperware and fuel tank have to be removed. I sent mine off to Module Masters. Shipping back and forth was the slowest part. Y bike was down for 3 weeks in total. Once back, install, bled the brakes, cycled the ABS pump with my GS911, bled once more, and rode on. No issues and no more fault codes. Cost $250 and my time. I’ve heard if you take it to a BMW dealer it is around $1k. Videos in the tech section of this forum are a big help. Here is the Module Masters link https://superactionhero.myshopify.c...q=my_motorcycle~yr_2011~mk_bmw~md_r1200rt-k26
Is it safe to ride with that failure? Are brakes normal just no anti lock or are they reduced in performance? I have read they loose performance in limp mode.
Hydraulic action should not change with the ABS circuits and valves disabled. If a dump valve was leaking or stuck open causing your issue, that would greatly reduce braking but you would know it already.
When the ABS fails the brake are the same as conventional brakes. You can lock up the front wheel if you grab a handful so be mindful. Us old timers grew up on threshold braking.
All my previous and current bikes are non abs so I know all about threshold.
So the ABS module was a low voltage error and once I cleared it, it did not come back. The only code is 10491 which seems to be the EWS Ring Antenna.
